Dash Lights are out!! Fuses are all good
Old Sep 24, 2004 | 11:15 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I was driving home from the airport, decided to stop for a bite to eat. Pulled into the parking lot (Dash lights working fine), and shut off my car. Then I decided just to go home, so I then started my car up and proceeded to drive away. It was at this point that I noticed the dash lights not working. The next morning, I checked all the fuses in the fuse box and they are all okay. Everything else in the car seems to be working, when I push the dimmer switch all the way up to turn on the interior lights, it works fine, so Im thinking its not the dimmer switch. Is there another fuse somewhere in behind the dash?? I replaced all the dash bulbs about 3 years ago, whats the chances they all burnt out at the same time??
Any ideas?? Cause Im stumped. Im going to pull the dash apart this weekend, so Im hoping to get some input on what to look for?
Cheers
AD
Old Sep 24, 2004 | 09:52 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Does anyone have any ideas?? Its nasty driving at night, not seeing your guages.
Old Sep 24, 2004 | 11:57 PM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
I wish I had the answer- I'm in the same boat... I was installing 145mph glow gauges faces on my 92Z when I ran into a problem. While I was disconnecting my fog lamp switch I accidentally made a bad contact with the end of a flathead screwdriver. I replaced the blown fuse but later noticed that my dash lights were out. I've rechecked all of the fuses and they are fine. My dome light comes on as well. I'm wondering if a relay could possibly be involved in this situation? I'll probably work on my car again tomorrow so I'll let you know if I find anything out... Until this problem is fixed I guess we will both be living dangerously.
Old May 19, 2005 | 09:45 AM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
Did you guys ever figure it out, because I did the same thing trying to fix my fog lights(made a bad connection).
Old May 19, 2005 | 10:56 AM
I got my dash lights working by replacing the remote dimmer module. It's a shiny cylinder-shaped thing under the dash. There's a good picture of it here on this post: https://www.thirdgen.org/techbb2/sho...hreadid=254117
Old Jul 31, 2011 | 07:12 PM
89redfirebird's Avatar
Re: Dash Lights are out!! Fuses are all good
what worked for me on my 91 camaro was the contact point for the gauges where they insert, i used some steel whool on both sides and it worked great after that
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
