Dash light problems
Old Aug 8, 2004 | 12:25 AM
Gtatransam1987's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 5.7 liter L98
Transmission: TH 700R4
Dash light problems
I have a problem with my dash lights I have replaced both the switches on th dash and I have checked the fuses and I also have replaced the chime assembly and checked all the bulbs. I am at my wits end please help.
Old Aug 8, 2004 | 10:56 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Welcome to the board. What exactly is your problem with the dash lights, need a few more specifics than what you have given.
Old Aug 8, 2004 | 10:58 AM
they don't turn on with the rest of the lights at all. sorry new to posting o a web board
Old Aug 8, 2004 | 11:19 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do you have the digital dash or a standard dash?
Old Aug 8, 2004 | 11:33 AM
standard dash I had the car checked by a mechanic friend and the only way he got the lights to work was to jump the dimmer unit. I just replaced the old one and thought that would end the problem but i was wrong.
Old Aug 8, 2004 | 11:49 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you have checked all the fuses and replaced the dimmer and light switch. The only thing left to check is the ground wire for the instrument panel. It is located under the dash just to the left of the steering column. Another question is, when you changed the dimmer switch, did you change the headlight dimmer switch or the remote dimmer switch?
Old Aug 8, 2004 | 11:56 AM
remote dimmer switch. ok i checked the ground wire and there are two of them is that right? they both have a good contact and the lights still don't work.
Is there anything else like another relay to check or any other type of control module that could fail?
Old Aug 8, 2004 | 06:26 PM
Vader's Avatar
There is no relay, but as Trickster alluded, there is the remote dimmer module (switching transistor).
You'll have to dive head-first into the driver's footwell, remove the lower dash trim panels, swing down the "Convenience Center", and peer backward toward the radio pod to see the module. The telltale will be the top of the TO-3 transistor case. It's silver and about the size of a nickel. Follow the brown wire from the light switch to the module, and you'll have the right item. This is only found on Firebirds, not Camaros.
Make sure the transistor isn't open E/C from an overload or shorted lamp. If it is, you can replace it with a standard AF/switching NPN transistor like an ECG98 (now NTE98).
The Convenience Center:
A peek at the dimmer module location:
Once you're under there, it will all start to look familiar.
Last edited by Vader; Oct 9, 2009 at 10:32 PM. Reason: Redirected Image File Links
Old Aug 8, 2004 | 07:02 PM
Thank You Very Much Trickster and Vader without your help I wouldn't have got this fixed as quick as I have. :hail: :lala:
Old Oct 6, 2004 | 11:09 PM
kaylin4u's Avatar
I have a 1991 firebird, with no dash lights either. I've checked the bulbs and fuses. I located what seems to be a 3 prong transistor. It was mounted under the dash on the left side of the steering column in some sort of heat sink. One of the wires is brown, and when I turned on the parking lights, I got a 12 volt signal from the brown wire.
Vader, could this be the transister I need to replace to get my dash lights up and running. The base for the connector is DELCO-REMY with the number 263 under it. The nickle mounted is a Motorola 1986902-2 Mexico 1E07.
Old Oct 6, 2004 | 11:18 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
I was just about to start a thread about thsi same problem. and my problem was intermittant. The lights were on , then they went out. Then came bakc on one time when i hit 4th gear, then when i shut the car off they havent come back on since. So im guessing its the ground wire that came loose. that a fair guess?
Old Oct 6, 2004 | 11:29 PM
kaylin4u's Avatar
Well, after I posted a PM to Vader and to this message, I found this post.
https://www.thirdgen.org/techbb2/sho...mer+transistor
I jumpered my brown wire to the center wire, and my dash lights came on for the first time. The only thing I can think on why it went out is because someone had ripped the stereo out of the car at one time and shorted this thing out. I'm going to try to goto autozone to see if they sell this transistor. But I believe this is going to fix my problem...thanks Vader. You fixed it before you even got a chance to post to my message
Old Oct 19, 2004 | 07:08 PM
F-Bobby's Avatar
ok i just thought of something. MY guage lights them selves dont work, but my chekc engine light still work and so does the seat belt, etc. and so does my radio (aftermarket) but also the lights on the HVAC and the trunk reliease etc dont work, and i also get no audible alert that my lights are on when i open the door. any idea what coudl cause this, i dont think its the ground.
Old Oct 19, 2004 | 07:44 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
The trunk release and the interior lights run off the same fuse. If the trunk release fails suddenly it's a dead give away. Replace the blown fuse and it should work like a charm. This happened to me last month, I immediately checked the fuses.
Old Oct 23, 2004 | 03:24 PM
F-Bobby's Avatar
my trunk release still works fine.
Old Oct 24, 2004 | 11:27 AM
Vader's Avatar
The warning chime unit requires some level of input from the dash liught circuit. If the dash lights are completely dead, the light warning chime will not operate.
For those of you with working lights, try it at home. Turn on the parking lamps with the ignition off and door open. You should hear that nasty little chime pinging away. Dim the dash lights fully, and it should stop. The only way the chime knows the lights are on is through the dash illumination circuit.
Old Oct 24, 2004 | 02:02 PM
F-Bobby's Avatar
yeah i have no audible alarm when i open the door, SO the guage lights dont work, but the ses light etc work, and my interior like like my dome light work. SO any clue whats wrong. Its not the fuse. and if it was the ground wouldnt the SES not work either.
Old Oct 24, 2004 | 06:48 PM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
YES same problem here, no illumination, all the indication lights work, none of the illuminating lights.
Old Oct 29, 2004 | 11:42 AM
stl-tom's Avatar
Car: 1985 Pontiac Trans Am
Engine: 5.0 - 4 bbl.
Same problem
My dash lights went out too last week-end. I still have a stock AM/FM radio that has been acting up (cutting in/out). Is it possible the radio could be causing my problem since it's LED is controlled by the dimmer too?
I've checked all the fuses and they are all fine. The interior lights work too - it's only the dash gauges/led on radio & A/C controls that don't light up.
I'm thinking this thread probably covers it:
https://www.thirdgen.org/techbb2/sho...hreadid=240097
If the power transistor is bad, is that an item that can be picked up at Radio Shack/AutoZone or a Pontiac dealer?
I've read and re-read the posts above but am still having problems figuring it out. Could someone translate into "Electronics for dummies" language?
Thanks!
Old Nov 16, 2004 | 03:32 PM
F-Bobby's Avatar
ok ive goen back to try to fix this problem again. IM hopin someone can steer me in the right direction on this. so i can get them working.
I have no gaue lights, and no audible tone when i open the door, ive replaced the dimer switch and it still dint work. The fuse is good. is the only thing left that could cause this the transistor in the convience center?
Old Nov 21, 2004 | 08:43 PM
stl-tom's Avatar
The weather was nice today so I decided to tackle the no dash problem I posted about a few week ago. Once I found the transitor mounted on the heat sink, I took it apart and cleaned the terminals and put it back in and it WORKS!
For those hanging similiar problems with your 'Birds, feel free to email me. I took some pictures and would be glad to email them to you.
Thanks for a great forum!
Tom
Old Jul 24, 2009 | 08:35 PM
vipertech92's Avatar
Re: Dash light problems
I lost my dash lights about 5 months ago.I just started my car one day and they didnt work.I was told that i needed to check the cig. lighter for anything and as soon as i did i found a penny in it.I can only figure that that was the problem.the blinker lights and headlight icon still light up.i used a test light to check the wires and i found that the power stops behind the resistor switch.there is power behind it leading into the wire but there is no power going to the fuse box for that fuse from that switch.what can i do to fix it.IF YOU CAN HELP PLEASE E-MAIL ME AT BMDEAS101@HOTMAIL.COM....THANKS
Old Sep 12, 2009 | 09:48 PM
astuterror's Avatar
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Old Sep 12, 2009 | 09:50 PM
astuterror's Avatar
I just encountered the same problem with the '91 trans am GTA that I just purchased, with your guys help I changed out the remote dimmer module and problem resolved. Thank you so much!!!
Old Sep 30, 2009 | 10:31 PM
daedalous's Avatar
Car: 89 Formula
I know this is an ancient thread, but I'm having the same problem. I've attempted to locate the remote dimmer module spoken of in this thread but to no avail, I've searched everywhere and cannot find it. Does anyone still have any pictures of the transistor they could post?
Also, since I can't even get my head far enough up the dash to locate the sucker, how am I going to get at it to change it? Thanks.
Old May 16, 2010 | 09:41 PM
volver's Avatar
1: No dash lights. Interior lights come on when dimmer is fully scrolled to the top.
2: Replayed dimmer switch on the dash. ( no change )
3: Tracked green/white wire from dimmer to Transistor dimmer module.
4: Replaced transistor with one from Radioshack
5: Dash lights light up very dim. Door bell now chimes. As the dimmer is scrolled up the chime gets louder, the dash lights never get brighter than a small glow. When the dimmer is scrolled to the very top the dash lights become very bright and the door bell chimes loudly.
6: When the ignition key is turned on I can control the temperature gauge with the dimmer switch. I can also make the voltage gauge wiggle.
Any ideas on what might have exploded. or should i just replace everything one by one?
If i have to replace everything were do i get parts? The junkyard is picked over and i have heard that GM has discontinued all third gen parts.
Old Oct 12, 2010 | 08:17 PM
olefirebird's Avatar
Car: 1982 Pontiac Firebird
Engine: 4 cyl
Ok so I just bout an 82 Firebird. Went out there searching and replaced a fuse and wala the lights all work. Now as long as that works for long time then im good with replacing it a couple times a year (if its a short). But hopefully it fixes it completely.
Old Feb 5, 2011 | 12:44 AM
adilson delima's Avatar
Transmission: AUTO
can somebody tell me how do i get access to the light bulb in dash on a 90 rs camaro? please i only need to replace one of them the left side! thx
Old Mar 26, 2011 | 01:06 PM
aaronp91's Avatar
i have a 85 firebird v6 2.8.. My battery was not charging so i replaced the battery and the alternator.. Battery still not charging the alternator has power going to it. i was told to check the cluster (dash) and see if the battery light came on.. it doesnt so i replaced all the light bulbs n the back of the cluster... Still no battery light... So what should i replace next? the little green housing the lights go n? Were can i get them? and which light excatly is the battery light? i was told wit that light not working that the alternator will jus run full speed causing it to heat up very fast and pop belt after belt. Which is what it is doing!! PLZZZ HELP ME!!! you can e mail me at aaronpost91@yahoo.com or call me or text me at 843 364 2548... i need to fix this asap ty so much
Old Jul 15, 2011 | 07:36 PM
jaypug92's Avatar
Car: 92 pontiac firebird & 92 camaro RS
Engine: 3.1 LHO V6
Transmission: Auto trany M5-A4
I have a 1992 Pontiac firebird convertable and I my dash and parking lights went out I change the bulbs and fuse. My head lights turn on but parking dosent. When I hit the breaks my parking and dash flash idk I'm so lost on this one so if any one can help that will be great!!! Thanks
email me at jaluke1@unoh.edu
I really need help can't drive at night with out parking and dash light!!!
Old Aug 11, 2011 | 09:23 AM
Johnnygeek's Avatar
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
ouch well if you didnt do any dash work or stereo swapping and basically it failed on its own I would suggest a connection issue corrosion is a pain.
remove fuses and relays and blinkers and stuff make sure every thing is good and has a clean connection.
Old Dec 11, 2011 | 01:28 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i would really like a true part name and number maybe order info or something else. need a new one. any help please
Old Mar 30, 2014 | 08:37 PM
RandyTyler2's Avatar
Car: 1986 Firebird
Engine: 350 Carbed
Very Helpful!
Old Aug 6, 2015 | 02:00 PM
SKIDOG74's Avatar
Car: 91' RS CAMARO
Engine: 305 V8
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
