trickster in need a diagram please
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
I need, if you can of a 84 firebird turn siginal diagram. Thanks in advance,
Kyle
Btw That whole choke light/popping fuse thing was a bad solonoid for the hood air scoop
and the code 24 was cleared up with a new cap and rotor
Kyle
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello cyipher,
Glad to see you got the other problems resolved. By turn signal diagram, do you mean the wiring diagram for the lights or the wiring on the steering wheel?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
One side or both sides?
Check the turn signal flasher unit located behind the instrument panel to the right of the steering column. It is a little round unit.
Check the turn signal flasher unit located behind the instrument panel to the right of the steering column. It is a little round unit. Last edited by Trickster; Sep 26, 2004 at 10:48 PM.
