need schematics to hook up alarm
Old Sep 30, 2004 | 06:48 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Just bought an Airwolf alarm system and am having a bit of trouble finding the wires under the dash to hook them to. The detail of the alarm can be found on this site as a adobe PDF file.
http://www.designtech-intl.com/Conte...fbrochure.pdf/
Searched about 6 pages of results but cant find to much.. All I need is pretty simple, just need some schematics that tells me which wires are what under a 89 firebird's dash. haynes manual was about worthless for this but thats no suprise! lol..
Step one was to tap into the key cylinder wiring. Since I didnt have the schematics I was using a volt metter to test which wires do what under certain conditions but there was one I just couldnt find and I checked all the wires that went into the colum that I could see. omg... I just answered my own question as I was searching for reference web sits that I could use to ask questions.. HA! Well.. Post anything that you think may help me in hooking this up if you could, like all the common things that someone may run into when hooking up an alarm system like this for the first time. I refuse to have some "pro" work on it for a chunk of my change.. OH! How is this going to work with the vats or pass key system?
Check this out, its what I found " vehicle wire colors "
http://www.designtech-intl.com/Conte...rt/wirecolors/
Old Sep 30, 2004 | 06:53 PM
about the vats, this may not even be an issue actually. I have my fuel pump wired to turn on with the ignition, later I'll probably install a toggle switch for that in a lock box. And lets get crazy with the box and install a tamper device on it that flips another hidden switch if the box is tampered with! ok I think to hard..
Incase anyone needs the vats info....
http://www.designtech-intl.com/Conte...04/note237.pdf
$750 L98
Feb 1, 2025 02:25 PM
thunder57
Nov 7, 2015 02:28 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Gordonr1973
Sep 29, 2015 11:59 AM
