Is an electric speedo independant of the ECM??
Old Oct 8, 2004 | 07:26 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
I need to know if the 140 TA electric speedos are independant of the VSS? I am carbed w/ the 85 mph mechanical speedo and most of all the factory wiring including the ecm wiring has been chopped out or removed because it's no longer necessary.
Is it possible to make a custom wiring harness for the electric speedo to connect to the VSS on the tranny??? if so what would I need?
Please help because it would be nice to have a speedo.
Old Oct 9, 2004 | 12:07 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
http://www.hioutput.com/tech/speedo.html
This is what I did in my Formula.
If you plan to swap in an entire 86-92 cluster, you may need to re-pin the connectors; I haven't been able to find out if they changed between 84 and 85 or if it was between 85 and 86 (when the electric speedo was introduced in the 'birds).
GTAman
Jul 3, 2024 07:29 PM
gta892000
Aug 11, 2019 11:16 AM
TrevinE
Sep 14, 2015 03:20 PM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
