turn signal, windows -> slow
Old Oct 15, 2004 | 02:54 PM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
I noticed that the el. gauge didn't show the right voltage ( approx. 10V) when i drove into a parking lot and the turn signal was really slow. Also the power windows are moving slow.
After an hour I started as usual, no problems. only the gauge was on ~10V and the accessoires worked still slow. I had to drive with the headlights on because it is now night in europe still no problem and the gauge readings was all the way the same!
Any suggestions what the problem could be? (Battery was changed a few weeks ago)
Thanks for the input
Pat
Old Oct 16, 2004 | 06:54 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Sounds like the generator is not charging. Output when charging is between 13.5-14.9 volts. At 10 you are running off the battery and it's getting low. You need to service the charging system.
Old Oct 17, 2004 | 07:52 AM
Car: '91 Z28
Engine: LB9
could it be that the outgoing alternator is making some noise?
I have some strange noise like a ghost witch is rpm dependent... so i assume this noise must come from a belt driven accessoire.
Old Mar 31, 2005 | 05:13 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Alternator heading south. The noise is more or less the bearings as usual.
The 730 TPI usually wont run on a voltage lower than 10.5v and beyond. Get a testor and test the battry while its runing and after you have cut if off.
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
