trickster still cant figure it out
Old Oct 16, 2004 | 10:59 PM
ManWitThePlan's Avatar
Car: 1990 IROC Z
Engine: 350 tuned port injection
Transmission: t-56 6 speed
the SES light always stays on. I cant get it to read a trouble code, it doesnt matter if i use a code reader or if i just jump across it like it says in the haynes manual. I am going to try grounding that AC pressure switch in the morning and i will get back with yall.
Old Oct 17, 2004 | 07:28 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It sounds like you either have a short to ground between the ECM and the ALDL or you have a bad mem-cal or a bad ECM. I will send you a schematic of this and a trouble shooting chart for it when I get off work today.
Old Oct 17, 2004 | 06:15 PM
Car: 1990 IROC Z
i have put a new ECM in the car so to the best of my knowledge its not that. are the schematics you are talking about going to be able to give me a general idea of where the short to ground is?
Old Oct 17, 2004 | 08:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well it is only a short distance from the ALDL to the ECM, so yeah it will put you in the general area. When you put the new ECM in, did you put a new chip in or did you use the old one?
Old Oct 17, 2004 | 08:33 PM
Car: 1990 IROC Z
i just used the old chip. if that is the cause where in the world would i get a new one? and also would that come and go as a short may do??
also do i just take the wires out of the harness at the ECM for the ALDL to see if it is shorted to ground???
Old Oct 17, 2004 | 08:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Give me a couple of minutes and I will post that chart for you.
Old Oct 17, 2004 | 09:15 PM
Car: 1990 IROC Z
have you got those charts you were talking about earlier?? they would be really helpful.
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is that chart that I was referring too.
Old Oct 17, 2004 | 09:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2. BTW, this is out of the 1990 GM service manual for the camaros.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
