Im about fed up with electronics on my car and I've never had problems before
Old Oct 18, 2004 | 08:30 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
I have a 92 Camaro RS 305 tbi. I have done many mods with the car running fine after each one. A while back I installed some Hedman Shorties on it and just unplugged the O2 and sat it to the side until I could get a bung welded on later. Of course it runs rich for this period of time because the ecm is getting a lean signal. So the time comes to weld a bung on and I go buy a new O2 and install it(finally some better gas mileage). So its running fine for a while and then I notice something when im at idle. It feels almost like a miss or a slight hesitation. Now, a month later, it is so bad that my car is dieing at lights and im running rich, really rich. Im going through tanks like crazy. BTW, I already rebuilt the TBI unit with new gasket and o ring kit, cleaned the IAC like everyone said to and checked my MAP, TPS and a number of other things. What is going on??!! Any help would be appreciated.
Old Oct 19, 2004 | 06:47 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It not an uncommon problem. The 5L 'stangs won't idle at all with headers. The exhaust gas is too cold to keep the sensor in it's operating range. I posted an article in the general section about heated O2 sensors. Get a Bosch universal heated O2 sensor and I'll bet it solves your problem. The O2 has to be in the 1200-1400 degree range to properly manage fuel delivery. Headers and low restriction exhaust scavenge so well that the sensor stays out of optimum range. A heated sensor generally solves this problem. Make sure you clear the ECM codes also when done.
Ghettobird52
Jul 5, 2024 11:18 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
