Motor Pulldown Question (yes, another one)
Old Oct 21, 2004 | 10:06 PM
Needin' Tires's Avatar
Car: '98 Z28 M6 & '89 IROC-Z 350tpi
Ok guys, I DID SEARCH , and all I found was topics relating to hatches not unlatching or the motor wouldn't pull it down, or kept running. This is not my problem.
My problem is this:
I bought the car, and the hatch pulldown assembley was completely dissassembled. A bungee cord was holding the hatch shut. I bought a used pulldown assembley from a person. I installed it and the latch is stuck in the down position. The hatch itself will not latch. Any ideas on what might be the problem??
Thanks guys an gals.
Robert
Old Oct 21, 2004 | 10:46 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You may have the wrong motor/latch as compred to the strike thats on the declid... there is 2 different styles...
Top is older (on my 87), lower is newer style (on my 91). When they changed is beyond me. The strikes (pictured) are interchangable on the decklids w/o mods though...
Old Oct 22, 2004 | 03:16 AM
Well, the latch mechanism came from a 1989 IROC and my car is a 1989 IROC as well. I don't see how there could be a difference. It looks just like the one that was in it.
Old Oct 22, 2004 | 08:03 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
Make sure its all lining up.
If it is.. you should be able to have it latch even though it's all the way down. Just close it..."hard" Having it latched would make it able to pop and rise up too I think. Does on mine from what I remember at least.
Old Oct 22, 2004 | 03:50 PM
koll's Avatar
Car: 1991 Pontiac T/A Vert
Mine just went out for no reason about 5 minutes ago. Its an 88 IROC Z. Motor stuck in the down position, hatch stuck doing nothing even if I press real hard.
Old Oct 25, 2004 | 12:47 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
The problem is that the motor thinks the hatch is already closed, so it cant pull the hatch down. Since the hatch isnt actually latched in the motor, the motor wont release it.
Just stick a pen in the motor(from the top), I can't remember exactly where, but just push lightly down on one of the things and the motor will return to the open position.
I can't be bothered to go out and look, but its incredibly simple, so I don't think thats necessary anyway.
Old Oct 25, 2004 | 10:11 AM
thanks guys, but i found out the problem. first off there was no fuse in the acc power fuse place. that fixed it. then, i had the latch tightened too far down, so when the motor pulled it down, it wouldn't shut off. so i popped the hatch, loosened up the bolts, shut the hatch, let the motor stop running and tightened up the bolts. that was it.
thanks guys for all of your suggestions
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Cleotiz
Jan 6, 2018 08:56 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
