How do I bypass the computer.
Old Oct 23, 2004 | 01:04 AM
Mechanix's Avatar
Car: 1985 Camaro Berlinetta
Engine: 305 sm block chevy
First my dash died and now I'm tearing down the engine and replacing parts and if at all possible I would like to bypass the computer. Can anyone tell me how to do this and what kind of parts I would need?
Old Oct 24, 2004 | 10:58 AM
Vader's Avatar
You'll need a fuel system that does not rely on an ECM. You'll need a distributor with an advance systemn that does not rely on an ECM. If you have an electric fuel pump (you might on an '85) you'll need a means to operate the fuel pump when the ignition is turned ON.
If you need to meet an emissions inspection requirement, you may not be able to accomplish that without am ECM to monitor the O² sensor and adjust fuel mixture accordingly.
Old Oct 26, 2004 | 08:33 PM
Mechanix's Avatar
So far there is no emission inspection. theres a mechanical feul pump on the block. is there a way to be able to use the current distributer without the computer. any help would be apreciated. Do i have to do anything to the ignition? Also I'm going to have to replace the carb right? also do I just yank the computer out or are there other things using it beside the motor?
Old Oct 26, 2004 | 08:34 PM
Mechanix's Avatar
Oh and thnx a lot Vader I'm only seventeen and pretty much new to cars and my dad says the computers came way after his time so he's not sure.
Old Oct 30, 2004 | 05:59 PM
hookedon3gen's Avatar
Car: 88 camaro
Engine: 383 carbed
Did some one switch engines, from a fuel injected motor to a carburated one? Even with a mechanical fuel pump you still have to have a gravity draw from the fuel tank and they have different fuel pressures. It's not as simple as one may think it is.
Old Oct 30, 2004 | 10:43 PM
Rage13's Avatar
Car: 89 Firebird
if you get a new or rebuilt distributor make sure and check the pick up coil.. i bought a "new" distributor from the local auto store and had been having erratic problems (random no spark) for the last 6 months trying to figure out what it was.. what a PITA.
Old Nov 1, 2004 | 06:49 AM
rol1's Avatar
Car: 92 bird
Engine: 6 cyl
Transmission: auto
A link to articles in another post had a link to megasquirt. This would allow you run without the ecu. Then the ecu would only be needed if other compoents need it.
http://www.megasquirt.info/
$750 L98
Feb 1, 2025 02:25 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
WejaZ28
Oct 3, 2015 07:38 PM
Formula8r89
Sep 22, 2015 04:24 PM
Deemax
Sep 12, 2015 06:53 PM
