Switch LEDs
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Switch LEDs
I did a search for this but found nothing.
Anyone know part numbers (RadioShack, DigiKey, etc) for the amber and green LEDs inside the dash switches (fog lamps,. defroster)? I bought some from RadioShack, size matched and were the only ones, but the package doesn't indicate the voltage. Blew the LED as soon as I turned the switch on
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Depending on the color, they only need between 2 and 3.5 volts.
Red, yellow, and amber only need 2.0-2.2 volts, while white and blue can handle upwards of 3.5.
You need to use a 680 to 1k-ohm resistor in line with either lead of the LED to drop the current/voltage down to a safe level.
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Yeah I knew I'd probably have to do that, but hoping as a last resort. The switches have no resistors inline, just the LED in a little plastic holder that comes out.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
kind of a pain, but its doable. the only other option would be to find a LED made for 12v. thoes usually have the resistor built in.
Car: 1989 IROC
check this website out, they have a lotf LEDs for cars, maybe you can find one that will work. Good luck. www.superbrightleds.com
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
There is a lens, yes, but behind it is an LED. I'll take a photo next time I pull it apart (if possible). It looks just like the RadioShack piece I have too.
Hopefully I'll find the perfect match for those who need to replace the ones in their switches.
It is a relatively simple procedure - twist holder and remove bulb - and much better than spending $40+ for a new switch.
Randomtask2
Sep 10, 2015 08:37 AM
