horn loose?
Old Nov 4, 2004 | 08:18 PM
Airpak's Avatar
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
horn loose?
i have a 82 camaro, round horn
it has been honking when i go around corners, i think its loose or something so i was wondering how to take it off to see if i could fix it, who needs a horn newayz
or what can i do to disable it.
ps. i know nothing about car electronic wiring.
Old Nov 4, 2004 | 11:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just pop it off and check the wiring under it where it connects to the steering wheel. You might also have a loose wire at the horn in the left fender well.
Old Nov 4, 2004 | 11:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Just grab it & pull.It comes right off.theres ONE wire to disconnect.That wire also disconnects from the column.If you want to disable the horn.
Veaceonee
Sep 29, 2016 08:15 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
92camaro350cci
Oct 14, 2015 09:29 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
reactor60
Sep 22, 2015 01:44 PM
