brake light issues...... please help.
Old Nov 11, 2004 | 03:29 AM
87 L98 TA's Avatar
Car: 1987 Trans Am
I pulled the column to do the torx bolts, and thats where I went wrong. The 2 main brake lights no longer work, but the 3rd does. There was what I believe to be a cheap splice done on the white wire just outside of the wire cover.
The car has remote start and when you're to press the brake without the key in the ignition it kills the car, thats why I believe thats the brake wire because it doesn't kill the car any more. When I connected the 2 open ends of the white wire they still didn't work...
can anyone tell me if this is the problem, or what color wires may be the problem???
Old Nov 11, 2004 | 04:45 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
check your fuse... u may have pinched or snipped a wire and shorted something while you were working.
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
