No Accessory position on 1986 IROC ?
Old Nov 12, 2004 | 03:02 PM
Pacer's Avatar
Car: 82 Camaro Pace Car & 1989 IROC
Engine: LG4. & 350 TPI
Transmission: 200C
No Accessory position?
I cannot put the ignition switch into "ACC" postion?
Even with the car in Neutral etc ... key won't rotate switch backwards?
The only way I can play the radio with car not running is with the key forward. Meaning all my diagnostic lights are lit.
My 82 Z28 has "Acc" ?
Any suggestions?
Pacer
Old Nov 12, 2004 | 03:05 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
my 86 iroc-z does the same exact thing... i have also wondered why also.....
Old Nov 12, 2004 | 03:16 PM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
2nd try @ this reply..
here's my experience:
When my ignition switch went south, my wife decided to have her dad confirm it and he must have cranked the heck out of the key and bent the actuating rod from the lock to the switch.
I found this out because after I replaced the switch I had no acc position nor would it roll back.
Straightened the rod and adjusted switch position and all was normal.
Steven 86IROC-Z
May 24, 2026 04:52 AM
michealleger
Aug 26, 2015 03:29 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
mustangman65_79
Aug 11, 2015 03:17 PM
