Window won't let up
Old Nov 16, 2004 | 03:52 PM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
Window won't let up
My Formula had been sitting for about a year before I bought it. When I put a battery in it and let the window down, it would not let let back up. If I continue to hit the down button, it jumps as if the motor is still good. Any suggestions of what's wrong and how to fix it.
Old Nov 16, 2004 | 06:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Pull the door panel off and check the window tracks, clean and lube as neccessary. Lube the runners with a white lithium grease in a spray can.
Old Nov 17, 2004 | 04:47 PM
1989Iroc-Z-350's Avatar
Car: 1989 Iroc-Z
It could also be a loose connection inside the motor, try tapping on the end of the motor to move the armature then try to roll it up. If that fixes it then the motor has worn or dirty brushes and may need to be replaced.
david068513
Sep 18, 2015 10:36 AM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
