Perma-Cool 30-Amp A/C Relay
Old Nov 19, 2004 | 12:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Has anyone ever used this. If so, how does it hook up?
"This 30-amp air conditioning relay will activate your electric fan when the air conditioning is turned on."
JamesC
Old Nov 19, 2004 | 12:37 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Nothing fancy, just an overpriced 99c automotive relay.
If you have some electrical experience, you will know how to hook it up (regular 5-prong hookup). If you don't, leave it to the pro's. You dont' want to burn your car down.
You can get automotive relays here for a very reasonable price: http://mcm.newark.com/NewarkWebComme...SKU=26-534&N=4
Lou
Attached Thumbnails Perma-Cool 30-Amp A/C Relay-3927011-1-.jpg
Old Nov 19, 2004 | 11:55 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
There is a switch on the back of the A/C control panel. It is wired in parallel with the fan thermal switch. It supplies a ground to the electric fan relay when ever the AC is on MAX or NORM to turn on the fan. No need for another relay!!!
Old Nov 20, 2004 | 05:47 AM
JamesC's Avatar
So this relay is to be used in conjunction with a car already equipped with an electric fan? (I'm trying to swap from clutch to stock dual electric).
JamesC
Old Nov 20, 2004 | 09:06 PM
83_1/2 L69's Avatar
Engine: 305 CC-carb
Sorry James,
Didn't mean to confuse you. My reply was meant for someone with a factory electric fan, which already has this relay (no need to add an extra).
Since you are upgrading from a mech fan, you will need some kind of relay.
This is just a standard 12 volt automotive relay that PermaCool is reselling at marked up price (that’s what BB Lou is saying).
jrdturbo
Mar 31, 2016 02:58 PM
thunder57
Nov 7, 2015 02:28 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
