Wiring harness necassary?
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
how much Wiring harness is necassary?
How much of my wiring harness behind the dash do i really need im goin to be runnin a carbed motor with no heat/ac jus a raido n the bare essentials to drive on the street
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
when i converted my other iroc to carb i pretty much eliminated everything except a ground, a hot and a signal wire from under my dash, got rid of everything, ecm harness you name it, but be carefull that you dont get rid of any of your body line for your lights and such. i think i weighed everything that i pulled from under the dash and it was like 35 pounds
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
when we did my brothers car we went from a v6 to v8 and we removed the ecm and the complete wire harness from the passenger side
Car: 87 Formula
Engine: 350 tpi
ok thanks guys im about to pull the motor this weekend then im goin to hit up the eletric system (not one of my favortie parts tho lol)
