Solved my problem! Now just dont know where to safely power electric fan!URGENT!
Old Nov 26, 2004 | 08:32 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I may have solved my charging problem.....the guy that sold me the car was goign to hook up an electric fan switch, but this was after i drove the car/made the deposit on it....so it drove fine before, and he didnt drive it at all after hooking the fan switch up, except to my house, and thats when the problem started (battery not charging). Well, i was looking for something that was causing the thing to not charge, and sure enough, on the red and black cable (the smaller of the two) on the positive battery cable, he had stripped away the rubber coating and just wrapped one of the wires going to the fan switch to it, then used a little electrical tape to hold it there. Did the same with another red wire i'm not sure where it goes to (probably the fan itself). Took those off and wrapped up the bare aeras with electrical tape, and since the gauges are working now, started it up, took it for a quick drive, played around with everything that would use up electricity.....volts seemed to stay at the same level! I'm almost positive that somehow it was because of the way he wired up the fan switch. Only problem now, is how do i get the fan to work? Where can i safely wire this stuff? Thanks
-Chris
Attached Thumbnails Solved my problem! Now just dont know where to safely power electric fan!URGENT!-bird-004.jpg
Old Nov 26, 2004 | 08:35 AM
another pic showing where the second wire goes....
Attached Thumbnails Solved my problem! Now just dont know where to safely power electric fan!URGENT!-bird-011.jpg
Old Nov 26, 2004 | 10:00 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i am not a pro at electrics but when i put dual lt1 fans on my car i just ran a relay off the ignition and battery
BRoss99
Aug 10, 2025 05:08 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
ezobens
Aug 19, 2015 10:29 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
