Ecm No Worky??
Old Nov 26, 2004 | 06:18 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Ecm No Worky??
i have a 2.8L and well i went to check my trouble codes just in case.....and nothing happened! i dunno if i dont have this feature, but i put a paper clip into the 2 slots (A and B according to haynes) and turned my key forward, and nothing happened. and i only have the top slots filled with metal contacts....is this normal? specs are 2.8 carbed
Old Nov 26, 2004 | 06:26 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Not sure about the way a 6 cylinder goes, but on the v8 motors you should get a code 12, and then any corresponding trouble codes after. Code 12 means no distributor signal, or something, which is normal. I would check the ecm fuse, and the connector itself. Let us know what you find.
Also, what makes you so sure there is trouble codes? Has the light came on and stayed on?
Old Nov 26, 2004 | 06:29 PM
Car: 1987 Z28
nah man, my car is just running crappy and i wanna know if something has been overlooked......but i just thought of something.....maybe my check engine light is burnt out ? its a possibility.....but yeah i will check on that tommorow thanx for responding man
Old Nov 26, 2004 | 06:36 PM
Hey, no problem. As a suggestion, you may want to check into starting with a basic tuneup on your camaro. A trouble code isnt always going to be set for a car running crappy. A code is set only if a sensor or the circuit of the sensor has a problem. A code wont be set for fouled plugs, burnt wires, dirty air filter, etc. Good luck bud!
Old Nov 27, 2004 | 01:15 AM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
The engine needs to be Off to get the 12 error code.
Old Nov 27, 2004 | 10:09 PM
Yeah, but he's got the 2.8 v6 which is distributor less. I don't know if it still gives that code but maybe means something else. I dunno.
Old Nov 27, 2004 | 10:11 PM
Wait nevermind if his car is an 83 it's not fuel injected, so it has a distributor.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
