HELP PLEASE car wont start!
Old Dec 6, 2004 | 06:47 PM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
my car died!i mean,the damn car wont start,it's a non comp.controlled car with a qjet,i was crusing by when he suddenly stalled and refuses to start,i changed the ignition module and the coil 'cus both tested faulty at autozone,but the car still doesn't start,i also hotwired the batt. terminal to no avail,there's no power to the batt terminal at the dist.cap but there is power to the tach terminal,i have an omega k9 alarm but she seems to work ok and has never failed,im out of ideas,there is power out of the ignition switch but it doesn' reach the distributor,thanks in advance
Old Dec 6, 2004 | 06:55 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Trying pulling the fuse to the alarm and see what happens. My car was doing the same thing and it turned out to be my car alarm. Once I pulled the fuse to the alarm the car started right up. Just a thought.
Old Dec 6, 2004 | 07:00 PM
sr.bond's Avatar
thanks ill check it out
Old Dec 6, 2004 | 09:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You might want to check your Park/Neutral switch on the shifter. That is what completes the circuit for power to go to the starter from the ignition switch. Just a thought..
Old Dec 7, 2004 | 01:08 PM
sr.bond's Avatar
actually the car is cranking but there is no spark whatsoever
Old Dec 7, 2004 | 01:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
How about pick-up coil?
Old Dec 7, 2004 | 03:05 PM
sr.bond's Avatar
not checked that.im onto that next,thanks,but if it were the pick up coil,there should be current at the batt terminal,shouldn'it?
Old Dec 7, 2004 | 03:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I think you lost me there. Do you mean the battery post or where exactly?
Old Dec 8, 2004 | 02:01 AM
sr.bond's Avatar
no,i mean the batt terminal at the dist.cap,the tach terminal has current when i turn on the ignition switch,but the batt terminal doesnt,i tried hotwiring the batt terminal to the positive side of the battery but the thing wont start,not a single spark,theres power coming out of the ignition switch but it doesnt reach the distributor,can my alarm be the culprit?i tried pulling the fuses out of it but nothing changed
Old Dec 11, 2004 | 04:03 AM
sr.bond's Avatar
any ideas folks?im still without a clue,changed module,pick up coil,coil,there is power to one lead at the distributor cap,disconnected alarm,even hotwired the damn car and still no f****n spark at all,the rotor is moving ok...so what could it be?
please think of somethin' guys.
p.s. a blown timing chain can do this?
Old Dec 12, 2004 | 11:59 AM
Morley's Avatar
No, if the timing chain were to break the rotor wouldn't turn.
Old Dec 12, 2004 | 02:37 PM
matlicker's Avatar
hmm
My car just recently did this to me. I started the car then it ran for about 10 seconds, then it just kicked the bucket. First I did the major things that commonly go wrong. Ignition mod, ignition coil, starter solenoid, didn't do the pickup coil though. I also replaced the knock sensor, which is another thing which it could be. None of those things fixed it. I ended up just replacing the distributor. Started right up after that. So i would say just pull the distributor, and take it someplace to have them inspect it, or else just buy yourself a new one. Good luck.
Old Dec 14, 2004 | 01:27 AM
sr.bond's Avatar
thanks mat,i'll check on that
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
