Trying to Run a fan Switch
Old Dec 9, 2004 | 12:33 PM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
What's up? I just bought a rocker switch for my electric fan, but I don't really know what I'm doing. The fan used to be running from the fuse box, until the wire got crappy and melted the fuse box. Any tips would be great. Thanks.
Old Dec 9, 2004 | 02:17 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
when i bought my car i found the a melted fan wire at the fuse box. the previous owner wired it to pull power straight from the fuse box. i bought a 30 amp relay and it solved the problem. 1 wire to ground. 1 to battery and 1 to keyed fuse. the relay draws straight from the battery.
Old Dec 19, 2004 | 06:05 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i got my fan wired
first rule.... use a relay.
2nd rule..... use a fuse.
wire the switch to power, and ground, and the acc part of the switch goes to the relay.
then the relay gets power and ground, and teh switch, and tehn to the fan.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
