Gauges
Old Dec 11, 2004 | 01:12 PM
Tiny5.0Firebird's Avatar
Car: 83 Firebird
Engine: 5.0
Transmission: 5 speed
Gauges
I have an 83 firebird w/cable driven gauges , my question is how hard would it be to convert to electric gauges ?
Old Dec 13, 2004 | 04:24 AM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
Re: Gauges
Having had to do this on my car, it can be hard or easy.
here is how i did it, I took the entire dash setup from a later firebird and swapped the whole dash unit. To get the RPM's and MPH working you will need an electric sending unit from a later transmission 86 and newer IIRC. I then swapped the dash in and used a later wiring harness that reads the VSS. It can be a pain being 83 odds are you are carbed. I do believe someone wrote a tech article on how to do this.
The hard way (and long way I think)
swap the dash cluster and do a hell of alot of wiring. thats it as simple as you can get it.
Old Dec 13, 2004 | 09:33 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
I did this for my 84 and also put a useful web page together back then http://la.rsson.com/speedo/speedo.html
If you need some parts (yellow buffer etc) let me know as I still have a couple of them e-mail me jan_l@rsson.com
Hope this helps.
Old Dec 13, 2004 | 03:04 PM
Car: 83 Firebird
Engine: 5.0
Gauges
Thanks alot, it doesn't seem too hard to do .
So I'll give it a shot . Thanks again and if I run into any problems I'll be writing back .
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
