glueing a battery back together? lol
Old Dec 15, 2004 | 11:39 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
hey guys I dropped my batter which was sitting on the tire of my car and i went to move the car(fenders are off etc) the negative terminal was still hoocked up, well bang I heard, and there the battery was with the negative terminal and some surrounding plastic with it broken right off, so I'm wondering if there are anyt adhisives that withstand battery fluid? or should i try to melt this back in with the other plastic?
I as well as you I'm shure, would figure having this set up wouldn't be safe, so is there any way to make a battery go bad? so I can get warranty on it? the phsyical damage isn't covered of course. at least if I sealed it up, then had a really bad battery I coudl take it to them and try to get a new one?
cheers
blake
Old Dec 15, 2004 | 11:55 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Don't heat up the plastic, one wrong move/punctured battery is NOT worth the trouble. Just get a new one, its not worth screwing around with something like this unless you are sure it's gonna be fine. Maybe a pic would help but personally I would screw around.
Old Dec 19, 2004 | 05:13 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: glueing a battery back together? lol
blake
wow first you have hard to understand english but next
:nono: :nono: :no: do not try any of that... the heat may blow your battery up on you and battery acid sucks.. glueing it is really stupid too. just go and spend the $50 on a new batt
Old Jan 3, 2005 | 12:35 PM
danwaite's Avatar
Car: 91 Pontiac Firebird
Engine: 305 soon 350
Let's think here, hydrogen, gases that come from a battery, Lindbergh, blew up because of what? You've guessed it right, HYDROGEN, take that battery back to walmart, napa, autozone, pay 45-50 bucks and get a new battery and get rid of that time bomb.
Just my two cents.
Old Jan 3, 2005 | 01:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
cheers
blake
Any auto parts store that you took it to would listen to your story, ask where you bought it from, take one look at it and raise the flag so high it would touch the moon and then some. Just bite the bullet and go buy a new battery and try not to repeat that mistake again.
Old Jan 3, 2005 | 02:29 PM
goofnrox's Avatar
That would be the Hindenburg.
I belive you are confused with Charles Lindberg.
Old Jan 3, 2005 | 03:37 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I thought Lindberg just kind of disappeared..
Had to.
Old Jan 3, 2005 | 09:46 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea the hindenburg did burn up..
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
