Lignts warning chime idea
Old Dec 16, 2004 | 12:29 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I have an 83 Z28 so there is no Lights On warning chime when you turn off the ignition and the lights are on. My ideas is to get a 12V buzzer/chime and connect the positive side of the chime to the lights and the negative side to the ignition. So if the lights are on and the ignition off the chime will sound. Will this work?
thanks,
Old Dec 20, 2004 | 09:42 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Ignition doesn't go the ground when off, it's open (indeterminate).
Old Dec 20, 2004 | 11:47 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Based on the fact that I didn't get any response I did some testing and it seems to work. I am using one of the IGN blade slots in the fuse block to connect the negative side of the chime and a tap into the INST (5 amp) green wire for Lights (positive side of chime). So whether the ignition is open or ground it seems to work. lights on, ignition off, chime on.
phil
Old Dec 21, 2004 | 07:39 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Well I'll be, got me. I'll have to go back to the manual and take a second look at was going on there....
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Ranbo108
Sep 9, 2015 12:20 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
