HELP!! my ign is being gay
Old Dec 19, 2004 | 05:21 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Well i have a problem.... i big annoying one.
My car has had a switch for the starter in it for over a year since i bought it, to give you background.
the problem is this....: i get in the car and turn the key( all power comes on and i hear the FP like normal) hit the starter switch and i hear the starter solenoid click then all power cuts out. Turn the key off then on and no pwer still. I wait for a lil while in frustration trying to check fuses and everything and try the key again and power comes back.
This started after i installed my H/U( i didnt rig anything just so you know). and it happens randomly, like i go to get gas, fill up, then turn the key and hit the switch and the problem shows itself.
also, all my fuses are fine except for the ACC fuse which blows instantly( i dont know if it was doin this b4 becasue i just recently put a fuse in there)
if you need a better description i am will to oblige.
Old Dec 19, 2004 | 05:27 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
think it has sumtin to do with the acc switch turning off
Old Dec 19, 2004 | 05:39 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
what do you mean... would that be my acc fuse or what...
Old Dec 19, 2004 | 05:43 PM
Car: 2002 SS
Engine: Ls1
well i kno this much... for just a regular ignition.. 1 click is acc.. next click is starter.. then it comes back and ur acc stays on.. what kind of ignition do u have? like did u wire up a push start or mess with any of that ? its weird man i hope somone else can help.. i kno that the acc switch needs to stay on in order for the car to stay running
Old Dec 19, 2004 | 05:52 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
oh okay...... the ign in the column is back for acc forward for run nad all the way forward for start,you know... like if i want to listen to mah radio only id put the key all teh way back( althouugh the lock to keep it back is messed because the car was broken into b4 i bought it and the column got f-ed up)
i didnt wire the switch up but i don know it needs to be replaced. Its been in the car since i bought it over a year ago w/o problems except once or twice that it got stuck on and the car kept trying to turn over.
i think the switch is going bad but i have no idea what is going on because when the problem happens i lose all power in mah car and my h/u resets due to no power. although if i turn the headlights on they still have power..
Old Dec 27, 2004 | 04:03 PM
Disifer's Avatar
Car: 1989 trans am
Engine: 305 tpi
Transmission: automatic
I think I get what you're saying. My cutlass used to do the same thing. Have you tried messing with the battery connections? Sometimes if I would mess with the ground (wiggle it or something) all of the power would be restored. Do you have the screw in battery cables or the ones that attach to the posts? The screw in ones seem kinda screwy if there is any corrosion at all. If it's anything other than that I have no clue. It was always fun when I'd want to leave work and all of the electrics would light up and then *click* turn the ignition and everything would go dead. I think it blew the fuse a couple of times but I put in a higher amperage fuse (i know that's bad) but as long as i wiggled the ground terminal it would get power back. Of course it would click off a couple more times but would eventually start.
Old Dec 28, 2004 | 02:22 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i just had to remove both the terminals when i installed my new amp. i have the screw in side terminals and both seemed okay and both were tight.
Old Dec 31, 2004 | 07:34 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
First thing I would check would be my battery connections - especially the ground. I have experienced exactly what you are describing before and cleaning and verifying the cables solved the problem. The ground is especially important here. You should check it both at the battery and at the chassis...
It could be in the weird jury rigged start button you describe... I does sound like somthing is not properly grounding.
Good Luck!
Speedy
Old Dec 31, 2004 | 08:10 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea ill replace the thing.. its kinda wiggly( if thats a word) and doesnt seem like its in its prime
GTAman
Sep 21, 2015 09:57 AM
KlayBuRn
Apr 7, 2001 11:00 AM
Wolfcoast
Feb 6, 2001 05:37 PM
IROCZ4BD3
Jan 12, 2001 12:25 PM
