heat sensor
Old Jan 5, 2005 | 05:23 PM
Nikon02's Avatar
Car: 86 iroc
Engine: crappy 350 crate i am building up
heat sensor
ok we put the heat sensor on the new crate motor and it works fine. it is new and we had a diagnostic tool pluged in, but the gauge on the dash is always saying it is way to hot. but at the same time the diagnostic says a nice 210 degrees.
any ideas what is wrong with the heat gauge?
Old Jan 5, 2005 | 05:52 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Two questions, what year and engine are we talking about, and which sensor did you replace?
Most 3rd gens have 3 coolant temp. sensors. One is the CTS (coolant temperature sensor), which is what the computer uses to read coolant temp. The second is the coolant temp. sending unit, which is what the temp. gauge in the gauge cluster uses to show coolant temp. The third is the fan switch, which is what causes the fan to turn on at a predetermined temp. (depends on engine).
Old Jan 5, 2005 | 06:24 PM
Nikon02's Avatar
Car: 86 iroc
86 iroc new motor is zz4 and there is only one heat sensor
Old Jan 5, 2005 | 09:01 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
That's why the gauge doesn't work then. It needs a resistance signal from a sending unit, and you don't have a sending unit installed.
Normally, the sending unit mounts in the driver's side head, between the #1 and #3 exhaust ports, and has a single green wire going to it. Find the wire, install a sending unit, and hook the wire to the unit.
Old Jan 6, 2005 | 11:56 AM
Nikon02's Avatar
Car: 86 iroc
i looked today the sending unit was there but the unit looked old so i replaced it and i am still having the same problems.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
