Alternator hook up for rear mount battery
Old Jan 11, 2005 | 08:19 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am getting ready to move my battery to the rear of the car. I noticed the charging wire for the alternator runs straight to the battery.
Can I : Run a wire fronm the battery post on the starter, up to a terminal mounted on the inner fenderwell, then connect the alt wire to this?
Or, do I need to run a wire all the way back to the battery?
Old Jan 11, 2005 | 09:00 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I believe you can run it to a terminal. When you do the rear mounted battery it is a good idea to use a remote silenoid(spelling). From there you should be able to hook up your alt power lead for the battery. At least I think.
Old Jan 11, 2005 | 09:06 AM
Car: 1971 Camaro
Engine: 427
I was going to use a remote silonoid, but have heard that it is not a good idea with a mini starter. Is this true?
Old Jan 11, 2005 | 09:17 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Well If you want to do it correctly you Will Place a Remote Starter Solenoid in the rear next to the battery (Like this one) and wire it similar to below. The main advantage is that the large 1/0 Guage Wire can be ran Under the car and will only have power while cranking also you can't put circut protection on the Starter wire because it draws so many amps and hooking you alt charge cable there won't have any protection. The 8Guage Wire can be ran throught the interior.
Also if you hook up the field sensing wire from the alt to the distribution block in the pic where it says 14.2 it will charge the battery and will mantain 14.2 Volts at that junction. So the rest of the car gets the proper voltage it requires. For more info on this type of stuff check these out.
http://www.madelectrical.com/electrical-tech.shtml
http://www.madelectrical.com/electri...evymain1.shtml
Also to get a Good deal on 1/0Guage or 2Guage Wire go to your local Welding store and by there Ground cable for a Mig in the Guage you want. it is $4-$5 cheaper than almost anywhere else
Attached Thumbnails Alternator hook up for rear mount battery-brians-wiring-layout.jpg
Old Jan 11, 2005 | 09:27 AM
Car: 1971 Camaro
Engine: 427
People with rear mount batterys. Where did you run the cable?
I was looking under, and was conserned about the cable being close to the exhaust.
Old Jan 11, 2005 | 01:14 PM
CraZ-28's Avatar
Car: 1991 Z-28
Not that I know of. I've been using one with my mini starter for almost 3 years now.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
