car is completly dead no electric
Old Jan 11, 2005 | 01:03 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I was installing a basss tube today and was attempting to hook up the wire to the postive terminal on the battery after it was conected i saw that i had no electric in the car at all. I disconnected it and reconnected and still no power. i checked all the fuses in the fuse box none of them are blown. The car is completly dead electrically nothing happens whenm i turn the key no headlights radio etc... any of idea what could have blown. I appreciate any thoughts
Old Jan 11, 2005 | 01:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try checking all your fusible links down at the starter and up near the battery.
Old Jan 11, 2005 | 10:27 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
check your fusible links? (at the starter where all your hotwires connect)
Old Jan 12, 2005 | 10:32 PM
THETANK's Avatar
Car: 91 rs
I found the problem well i am not sure what the problem was but I reconnected the battery cleaned the contacts which did not appear that dirty. I tightened up a few wiires comming off battery cables which the bolts were a little lose not very. The car started up fine afterwards. Thanks for the advice.
Jorlain
Aug 24, 2022 05:11 PM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 26, 2015 04:59 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
