Tach Idea
Car: 1984 camaro and a 1979 camaro
Engine: 305 and 350
Transmission: th200 and a th400
Tach Idea
Anyone by pass the wiring harness and just connected a wired from the starting on the plug that plugs in the circuit board to the distributor to operate the stock tach??
i think the wire is really bad on the harness it has been shorten and modifyied so much i wanted to replaced it but i don't know if it has a resistor in the wire or not?!?!
any info would be apreciated!!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well on your car if it is the 84 camaro that you are talking about. There is a black wire that runs from the distributor to the Tachometer filter, there is then a white wire that runs from the filter to connector C114 and from there to pin "D6" of connector C100 on the driver side firewall bulkhead. From there it is a white wire going to pin "11" on connector C1 of the instrument panel. Just pick a point there and put in a new wire.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
