Name these front wiring harness connectors
Old Feb 8, 2005 | 08:45 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hi everyone,
I've got a front wiring harness from an 89 Camaro and I can identify everything except for a couple of things. What is the tan/white looking circular one wire connector, and what is the two pin socket for, foglights? The relay I believe is for the headlights, right?
Anywho, here's the pic...
Old Feb 9, 2005 | 07:13 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The round one goes to the proportioning valve on the brake master cylinder. I will have to check for the other one.
Old Feb 10, 2005 | 01:50 PM
Car: 1989 Trans Am
Ah yes of course! Thanks for that. Any luck on the other connector?
Old Feb 10, 2005 | 06:25 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
If it is the 2 pin connector that you have in the picture then that goes to the high beam head light
Old Feb 10, 2005 | 08:58 PM
Car: 1989 Trans Am
Thanks for that info! What you say makes perfect sense because the harness did come from a Camaro and they had separate high beam lights unlike the the Firebirds.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
