Converting mechanical speedo output to digital gauge input?
I plan to use a TH400 in my 90' RS behind a 400sbc once I get it built to my liking. My question is how do I get the stock (digital input) speedo to work with the mechanical output on the TH400. I've done a little checking but have not turned up a whole lot. Any help would be greatly appreciated.
Thanks!
Thanks!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could try finding a VSS from a later model TH400-equipped truck with an electronic speedo.
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
I believe autometer makes a converter, and then you can use the dakota digital device to calibrate the speedometer.
Autometer part number 5291. $62.95 www.summitracing.com
Dakota Digital Part number SGI-5. $79.95 http://www.dakotadigital.com/Detail....-5/product.htm
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
find a tailshaft off a 454 ss pickup. it should have the correct electronic goodies. just get the right drive/driven gears for your tire/gear combo
ambainb
Apr 25, 2016 09:21 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
beachrodder
Aug 7, 2015 04:27 PM
