COMPLETELY re-wiring my car
Old Feb 12, 2005 | 10:01 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
the 383 is still bein built. This isnt a DD, so Im in no rush to get it runnin. Motor and trans have been pulled, along with the powertrain wire harness, fuse box, ECM and all other useless crap that Im not gonna need. Only thing I left was the wiring for the rear hatch pull down and taillights, and fuel pump of coruse.
My problem right now is the hatch pull down. I got the motor to push it up, but I cannot figure out how to make it retract. The only wires I can see that go to the front of the car is a red/white (hot), yellow/black(NO idea), and ground. I got all the wiring diagrams off of All Data Pro, but they kinda incomplete. I know if I get power to the red/white and ground the motor, itll raise the latch. How cna I get it to retract?! Or can I buy a regular hatch latch ( i think some came without all that pull-down crap )
Old Feb 15, 2005 | 12:13 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
did you check the micro switch on the unit. maybe its bad
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
