How many and what color wires to starter?
Old Feb 14, 2005 | 05:23 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I rewired the car for my Commander 950 ecm and now it won't crank. No clicks or nothing. How many wires should go to the starter and which ones? I think I have all the wires connected for the actual "starter", but I only have one purple wire on the starter solenoid. Should there be another one? Where does it come from?
Thanks.
Old Feb 14, 2005 | 10:22 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You should have three small red wires with large terminal lugs. Two of those wires will be connected to the same terminal lug, these are fusible links. You will also have a small purple wire going to a small post on the starter solenoid marked "S". Then you will have the large cable from the battery, the three red wires mentioned earlier go on the same post as the battery cable.
Old Feb 14, 2005 | 12:36 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Ok I got that. What else starts the car. Or just turns it over?
If I can't figure it out, I'm just going to put a push button start on it.
Old Feb 15, 2005 | 12:11 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i wonder if it has something to do with the vats since it is programed into the stock computer. is the stock computer still there in the car
Old Feb 15, 2005 | 09:18 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
No, the stock ecm is gone.
Old Feb 15, 2005 | 10:11 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you also remove the VATS control module and by-pass the starter enable relay?
Old Feb 15, 2005 | 12:30 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I don't think so. Where is the starter enable relay?
Old Feb 15, 2005 | 01:02 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ugh. i had to go thru this when i went to start my LS1.
it took me a half hour to find the relay... lol
its under the drivers side kickpanel.
do this:
take off the kickpanel.. the relay will be there, probly covered in sticky rubber/tar crap.
find the black wire with a yellow stripe on the relay connector..... shove a wire in there (leave the relay plugged in, just shove a wire in the back of the connector.)
touch that other end of the wire to a ground... i used my doorjam switch.
turn the key on, and you should feel the relay click... assuming you have the park or clutch switch still hooked up, the car will start now.
once you have that worked out, you can just bypass the relay entirely by connecting the two big wires together.... or you can put a switch in to ground the relay (starter disable switch)...
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
LT1Formula
Aug 20, 2015 09:36 PM
L98GTA87
Aug 5, 2015 11:02 PM
