weird headlight trouble....urgent help needed
Old Feb 14, 2005 | 11:14 PM
black84z28-4spd's Avatar
the other day i noticed my brights wont work when clicked on..the bulbs show that they are getting hardly any wattage.....the normal passenger side head light works perfect...nice and bright...not the driver side looks like its on its way out....i unplugged the bights to see if i had a bad wire and nothing...also the driver side side marker is doing the same exact thing...really dim.....when i turn the brights on the driver side blinker on the dash sorta lights up...dim but i can see the light from the bumb
what would cause this...bad light switch?...is the head light relay possibly going?....i dont thing its a ground because i was looking for ground and wiggling them
Old Feb 14, 2005 | 11:18 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
electrical problems are the worst, nows a good time to do an upgrade harness and all ^_^
Old Feb 14, 2005 | 11:39 PM
yea...damn things...it just started and is being gay
Old Feb 15, 2005 | 09:35 AM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Well
It may be a bad high beam light. I would check the light out first by sapping connectors see if that does naything. If it stays the same its the bulb if it changes it is the wiring. In which cause I would crac k out the good ole DVOm and check the ohms of the wires to makes sure there isn't excessive resistance. After that if you can't find anything I would check the sensor.
Old Feb 15, 2005 | 05:58 PM
you mean the relay up on the firewall?
Old Feb 16, 2005 | 05:50 PM
anyone else?
Old Feb 19, 2005 | 02:55 AM
ok....its not the low beam...thats fine...i can't find the ground that is loose....and no blown fuses....
my shop manual says the grounds are work for one side of the car and its only one side being lame..wtf?
Ghettobird52
Jul 5, 2024 11:18 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
