hatch and lighting
Old Feb 21, 2005 | 05:12 PM
man_of_steel27's Avatar
Car: 92 RS - For sale
Transmission: 700 R4
Axle/Gears: yup, it has a peg leg
hatch and lighting
1st question
I have a 92 rs, does the hatch switch have constant power all the time? mine does, I do not need to have the ignition on in order to open my hatch, is this normal?
2nd question
Since we cant access the archives, on the gauge panel/headlight switch circuit is there a transitor of some sort under the dash? My headlight switch is brand new, it works but I still do not have gauge/ dash panel lights. What am I missing? I had read in the archives a while back that there was a transitor in a heat sheild but I do not see it. i think that may be where my problem is but does any one have a pic of it?
any help, will help thanks guys
Old Feb 22, 2005 | 07:55 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
for the first question i'd say yes.......it would sorta suck not being able to open/close the hatch without the key in the ignition
Not sure bout the second question
Old Feb 22, 2005 | 03:55 PM
thanks makes sense
can anyone help with my second question
thanks
Old Feb 23, 2005 | 09:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes I can help you with that second question, the transistor that you have heard about is known as the remote dimmer module and is only found in the firebirds.
Vintageracer
Jan 10, 2020 05:33 PM
hydrolic144
Sep 8, 2015 06:55 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
