New harness...has only one relay?
Old Feb 25, 2005 | 04:16 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
Well i just got another wiring harness from an 87 TPI car and the one that was currently in the car, has 3 relays MAF power Fuel pump and one other relay, i was replacing the harness in the car (87) with another harness (87 supposedly) and the distributor plug is the larger plug im guessing for a large HEI(pre-87) not the small HEI like i have. the charcoal canister plug is on the opposite side(i think later years they switched sides for the battery) and when i looked at it all there was only one connector for the ESC module and one relay, i matched the wires and its for the Fuel Pump. now what am i missing here? did i get sent the wrong type of harness of a newer/older TPI car? it has a MAF sensor plug. the harness also has an extra connector where it meets the computer it has 3 wires 2 larger pink/black wires and one smaller tan/white. i am kind of stumped on this one. is there a certain year where it did not need the relays?i can take pics of everything if needed. someone please help me!
Old Feb 25, 2005 | 11:01 PM
Vader's Avatar
You may have a harness from an '85 Firebird TPI. They had no MAF relays under the hood and had the battery on the left, EVAP on the right.
Old Feb 26, 2005 | 02:36 AM
Car: 85 Camaro Z-28
Engine: 6.6
thanks, i figured that out when i looked for 85 TPI harness/ECM info guy sold me the wrong stuff said it was from his 87 TPI. wow ill be asking him about it on NE3G thanks again
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
