Auto-Dimming Mirror Help
Old Mar 7, 2005 | 01:04 PM
GTA Ryder's Avatar
I have an autodimming rear view mirror from my 87 trans am GTA... the motor was making noises, so I took the mirror apart and lubed the motor, changed the rubber bands in it, and re-soldered the piece that the harness plugs into. However, now when I plug the mirror back in, it continuously dims back and forth...
Anyone have any suggestions...even moreso, does anyone have any idea where I could get a wiring diagram of the mirror?
I re-checked everything I changed....it is all the same....i don't get it....
Old Mar 12, 2005 | 12:26 PM
Vader's Avatar
Sorry. I have no experience with the mechanical auto-dimmers. Hopefully, someone else will see this.
TTT
Old Mar 19, 2005 | 10:17 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
There's a couple of sensors activated by cams on the shaft for the pulleys that should stop the motor. I would check these. When I bench tested mine sometimes the sensor didn't activate and the motor kept going around in the same direction. I think this would result in the mirror cycling as you are describing. don't let this continue as I noticed the motor would smell quite a bit even though I shut it down early.
I have a question that I hope you could help me with. where did you locate replacement belts/rubber bands for it? I need these to get mine to work.
I have a loose connector on mine too.
Terry
Pac J
May 17, 2020 10:44 AM
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
scottmoyer
Sep 7, 2015 07:06 PM
