tach pegged out.
Old Mar 8, 2005 | 12:35 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
tach pegged out.
i've an 84z original carbed, I put in a b&m mega shifter the other day, now when I rewired the neutral safety and reverse to the new switchs that came with the shifter I noticed after everything was adjusted and properly installed the factory tach was pegged to the max. I had the car off during the simple wiring process and had not even took the car out for a road test, any reason for a tach to do this, the shifter and wiring shouldnt have had an effect on it that Im aware of. This car is not ecm controled and the tach worked great and I retain all my other gages and what not.
Old Mar 8, 2005 | 04:59 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
my car did that once. i went to turn it over and it went up and stayed half way so i turned it off and tryed starting again and it eventually got pegged. sure my battery was low so it took alittle while to start. anyway the way to fix it is to take off the 2 plastic covers infront of the gauges and just flip it back to zero. my still worked untill i swapped all autometer gauges in.
Old Mar 8, 2005 | 06:44 PM
ricktaylor's Avatar
Car: 84z28
tach pegged out
well I'll try that, its simple and fast but if it doesnt cut the mustard I guess we'll have ta go another route
$750 L98
Feb 1, 2025 02:25 PM
RedLeader289
May 28, 2019 01:47 PM
mattcanty
Oct 12, 2015 11:08 AM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
