Need C207 connector pinouts please
Old Mar 8, 2005 | 09:39 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
I need the pinouts for the C207 connector in an '87 LG4 Formula (VIN H). Apparently, several pins are different than the ones I found during a search. This is for a TPI conversion that's turning out to be more complicated than I expected.
Thanks!
Old Mar 9, 2005 | 05:17 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Durtybird,
I will send you the pin-outs when I get home from work today.
Old Mar 9, 2005 | 07:36 AM
DURTYBIRD's Avatar
Thanks a lot! I'm getting so close to being done.
Old Mar 10, 2005 | 11:18 AM
DURTYBIRD's Avatar
OK, after much digging in the '87 service manual schematics...this is what I have so far. I couldn't find info on Pin A and B...others I'm not positive on.
Looks like I still need those pinouts Trickster if you can come up with them. I think I may have enough here to get the car running, but I'd like to have it done all at once.
What a mess.
Old Mar 10, 2005 | 11:19 AM
DURTYBIRD's Avatar
Oops...forgot the attachment...
{edit} worthless document.
Old Mar 10, 2005 | 10:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Durtybird,
Here is the connector C207 pin-out for the VIN H L4. I will get you the pin-out for the TPI tomorrow and yes they are very different.
L4 pin-out Vin H C207
Pin “A”= brown wire from pin “B” connector “C2" of “ECM” to pin “C” of “ALDL”
Pin “B” = light green wire from pin “D” of “gear selector switch to pin “B” of “Back-up” switch
Pin “C” = white/dark green wire from pin “D” of “Light Driver Module” to pin “C” of “ECM”
Pin “D” = orange wire from pin “E” of fuel pump relay, black/orange wire to “FP/INJ 2" fuse.
Pin “E” = NOT USED
Pin “F” = pink/black wire from “ECM-IGN” fuse to “M/C” solenoid and emissions.
Pin “G” = dark blue wire from “TURN B/U” fuse to pin “A” of “Back-up switch.
Pin “H” = tan/black wire from pin “14" connector “C2" of instrument cluster (non-digital) or pin “B” connector “C1" (digital) to pin “P” connector “C2" of “ECM’
Pin “J” = tan/white wire from pin “C” of fuel pump relay to “Crank Fuse”.
Pin “K” = brown wire from pin “F”of “VSS” buffer (digital cluster) or pin “A” of “Inst. Cluster” (gages) to pin “16" connector “C1" of “ECM”
Pin “L” = brown wire from fuel pump to connector, tan/white wire to pin “A” of relay.
Pin “M” = black/white wire from ground to pin “5" for VSS buffer on connector “C2" for indicator gage cluster or pin “A” for VSS buffer on connector “C2" for digital gage cluster. (Ground is rear of right cylinder head)
Pin “N” = NOT USED
Pin “P” = purple wire from pin “A” connector “C1" of “Brake” switch to pin “A” of TCC solenoid switch on Automatic transmission 4 speed.
Pin “R” = orange/black wire from pin “B” of “Gear selector” switch (automatic only) to pin “H” connector “C2" of “ECM” or from “CH-FAN” fuse to pin “A” of “AUX. Coolant Fan Relay” (manuals only)
Old Mar 11, 2005 | 01:13 AM
DURTYBIRD's Avatar
WOW - I've got a lot of work ahead of me.
Thanks Trickster!
Old Mar 11, 2005 | 11:13 AM
DURTYBIRD's Avatar
Since it is SO different, would it be better to get the entire wiring harness from the 89 donor car and swap the whole thing over?
Old Mar 11, 2005 | 11:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Durtybird,
here is the TPI pin-out for connector C207 for the 87 firebird. I do not have the 89 firebird manual at the moment so I can't give you that exact pin-out right now. With the 89 wire harness and pin-outs there are some systems that are not in the 87 car.
L98 pin-out VIN F & 8
Pin “A” = brown wire from ECM pin “A2" connector “C1" to pin “C” of ALDL
Pin “B” = orange wire from pin “D” of fuel pump relay to C207 and then red wire to pin “G” of “ALDL”
Pin “C” = brown/white wire from pin “13" connector “C2" (ses light) of inst. Cluster to pin “A5" connector “C1" of ECM
Pin “D” = tan/white wire from pin “B2" of ECM connector “C1" to fuel pump & pin “A” of fuel pump relay
Pin “E” = white/black wire from pin “B” of “ALDL” to pin “A9" connector “C1" of ECM
Pin “F” = pink/black wire from “ECM-IGN” fuse to pin “A6" connector C1 of ECM & pin “B” of ESC module
Pin “G” = pink/black wire from “GAGES fuse to emissions
Pin “H” = tan/black wire from TCC solenoid to pin “F” of ALDL (automatics only)
Pin “J” = orange wire from ECM pin “A8" connector “C1" to pin “E” & “M” of ALDL
Pin “K” =brown wire from ECM pin “A10" connector “C1" to pin “F” of VSS buffer
Pin “L” = NOT USED
Pin “M” = black/white wire ground to back of each cylinder head
Pin “N” = orange/black wire from ECM pin “B10" connector “C1" to pin “B” og gear selector switch (auto only)
Pin “P” = purple wire from TCC solenoid to brake switch (automatics only)
Pin “R” = purple/white wire from Crank fuse to C207, then purple wire to pin “2" of cold start switch and purple/white wire from splice to pin “2" of cold start injector.
Old Mar 12, 2005 | 11:36 AM
DURTYBIRD's Avatar
Old Apr 13, 2005 | 09:49 AM
DURTYBIRD's Avatar
Originally posted by Trickster
Hello Durtybird,
It turns out that the LG4 and TPI harnesses are indeed quite different. Do you have any info on what systems would be different?
I have the opportunity to buy the IP harness from a TPI '87 Trans Am...has the power windows/locks connectors just like my car - would it be easier to swap the IP harness (dash and interior are already out) and then repin if needed?
Sorry if it seems like I'm having a hard time with this...
Old Apr 13, 2005 | 11:09 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Durtybird,
You are in luck, I just scored an 1989 firebird service manual off e-bay last week and hope to have it today or tomorrow.
Old Apr 13, 2005 | 11:16 AM
DURTYBIRD's Avatar
Hello Durtybird,
Hehehe...
Well, I may also have access to the '89 IP harness from the same car the engine harness is out of. Can you think of any reason this won't be easier than repinning the LG4 harness?
Thanks again!
Old Apr 13, 2005 | 12:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
NO!!!!!!!!!!, however there might (and I say "MIGHT", not will) be a couple of area's that will be questionable. I will know more once I get my manual.
Old Apr 13, 2005 | 12:15 PM
DURTYBIRD's Avatar
Sounds great.
Old Jul 30, 2013 | 02:07 PM
duece's Avatar
Car: 1990 Iroc Z convertible
Re: Need C207 connector pinouts please
Does anyone have the c207 connector pin outs for a 1989 iroc 350 tpi ?
Old Jan 19, 2016 | 10:34 PM
camsuper88's Avatar
Car: 88 iroc-z camaro
Engine: 305 tbi
Axle/Gears: idk
i am having the same problem in my 88 sc. i had the 305 tbi and now i have a 355 tpi but cant get my c207 connector to line up right. i took all the pins out of the engine side ( which is the tpi side) this is all i need to get it running. if you could help me get them in the right place i would be so happy. thanks.
Old Jan 19, 2016 | 11:58 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
http://berlinetta.info/C207.htm
http://"http://berlinetta.info/C207.....info/C207.htm
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
