trickster... need some wiring help again
Car: 91 formula
Transmission: t5
well when i was doing my 4th gen swap i came across this wire that was up on the right side of the car. the wire that goes to the left is pinkish, and there is a plug that connects to to the another pinkish wire that is labled auto and that runs somewhere to the far right of the car and disappears somewhere, there is a nother one with a plug coming from the far right that goes up to where the other ones are plugged in and it is a green wire with just the plug on it, and its labled man. now i can assume that it has something to do wiht what transmissoin is in the car and i have a auto right now and the auto wire is plugged in... but i will hopefully soon have a manual, and i figured i had to plug that in, so i was wondering what it does.
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Pictures would help. When I did mine I didn't come across ANY wire that were labeled. I do remember some pink wires and they went to the stereo system (maybe the Bose system amp, mine didn't come with that). sorry couldn't help more, come back with more info.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Like Norwood says, it would help if there were pictures of the wire that you are talking about. The only pink wire that I know for certain is under the dash on the right side is the one for the power antenna relay.
Car: 91 formula
Transmission: t5
will do when i get home... in new orleans at the moment.. . kinda disapointed only seen 1 thirgen
also can i get some digrams from you from that book ?
section 8a-33
veichle speed sensor: permenant magnetic generator thingy for the speedometer... my friend tried to do glow guages and took his needles off and now the cluster is all messed up and i think it lost its magnatism
Car: 91 formula
Transmission: t5
section 8a-33
section 8a-33
ttt
Glowsock
Jan 9, 2017 04:06 PM
