random fan wire
Old Mar 14, 2005 | 09:05 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
random fan wire
i have a wire that goes into my fuse box , held in by a fuse. some idiot thought this would be a good way to wire up the fan. there is a hot wire jammed into the fuse box, held in by the fuse controlling the wipers. what would be the proper way to wire this up?... thanks.
Old Mar 15, 2005 | 10:49 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Does your fuse panel have the "accessory" terminals along the top row? They are just single connector plugs that usually are labeled, and sometimes color coded.
If so, that is the best way to wire them up. On other applications all of those are run off of a 30A circuit breaker, not sure on your application.
However, if your fuse panel is setup with the accessory terminals, you can get a plug from the wrecking yard, then run an inline fuse on that wire. Just probe the terminals before deciding which to use. Some will be constant 12V, some will be 12V ignition on, some might be dimmed with headlight switch, etc.
I'm not familiar with the fuse panel in your year of car, so I apologize if this information is not correct for your application.
Old Mar 16, 2005 | 04:52 PM
Dingley's Avatar
Engine: LG4 305
i really can't see what you're talking about. could you show some pictures? btw, its an 1986 firebird.
Old Mar 16, 2005 | 06:01 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Unfortunately I don't have any pictures, nor capability to make any soon.
Look at your fuse panel as it is in the car. Are there some single connector "sockets" along the top rows that obviously don't take blade fuses? If so, those are what I'm describing.
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
fonzie85
Aug 13, 2015 11:50 AM
