which wire
Old Mar 15, 2005 | 12:21 AM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
which wire
which wire do i run to my kill switch to make the whole car shut off when i turn the kill switch off thanks.
Old Mar 19, 2005 | 10:13 AM
Vader's Avatar
The copper one.
Actually, there are many ways to disable the vehicle. You can interrupt the injection circuit, but that may not be ideal for the ECM outputs. You can interrupt the ignition power. You can interrupt the fuel pump. You could kill all power, but the radio presets and ECM BLM tables would be wiped out every time you do that.
Old Mar 21, 2005 | 12:26 AM
Car: 1987 iroc z
yeah i just figured it out i took the back alt wire and hooked to the positive side of the battery worked fine.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
