Starting problem
Old Mar 17, 2005 | 03:42 PM
ctw41's Avatar
Car: 92 Z-28
Transmission: automatic
Starting problem
Same 92 Z-28 that originally thought was a fuel problem.
Car was sitting 2 years w/o a battary. Installed new fuel pump and it works. Jumped A and B in the diagnostics and only got code 12. Cooling fans did not come on. Car will crank and oil pressure builds to over 30 psi while cranking but the engine doesn't fire.
Is the ECM dead? Where do I go from here?
Old Mar 18, 2005 | 07:15 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Three things to make it run, find what ya have and dont have
compression
fuel
spark
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
