need help with new guage cluster wiring....
Old Mar 19, 2005 | 05:34 PM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
i have a 91 Z28 with the electronic guages and im doing a custom guage set up using the AutoMeter 160MPH Speedo and it has a built in digital Odometer. how would i get the digital odometer to work correctly? is there anyway of converting from my current mechanical to digital?
Old Mar 21, 2005 | 09:16 PM
kd5boc's Avatar
Car: 92 RS
Wait...isn't the T-56 have a VSS in it? If you are going from digital to digital, just re-use the speedo wires coming from the VSS...you have the digital autometer speedo, right?
Tom
Old Mar 23, 2005 | 11:44 PM
Car: 91 Z28
speedo is analog and odometer is digital. what i need to know is how to get the odometer wired to work correctly?
Old Mar 24, 2005 | 08:22 AM
kd5boc's Avatar
Car: 92 RS
Then you have the digital speedo (the pointer will still be there...)
Just find the 2 wires from the VSS on the rear of the transmission and tap into them.
It should be pin A10 on your computer. (if you are carbed, just pull and use it, if you still have your computer, just tap into it.)
A10) is on the 24 pin computer connector, and should be a brown wire on teh locking tab side.
(Locking tab to left, A is on left side...1 starts at top and goes down to A24.)
Good Luck
Old Mar 24, 2005 | 02:04 PM
Car: 91 Z28
alright im gonna try this as soon as weather clears up...thanks
sheachopper
Jul 31, 2019 11:27 AM
