VSS differences?
Old Mar 21, 2005 | 11:08 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
VSS differences?
I pulled a 140 mph 89 Formula cluster from the junkyard. Now I did a search and found most of the info about installing the cluster into our 85 (mechanical speedo) T/A. Problem is, I don't know which VSS came on the Formy.
Does anyone know which VSS we would need to use to hook it into the 85? (305 TPI 700R4, 3.45 posi)
Even better question would be, can we just go back to the junkyards looking under any F-body w/ 700r4 tranny and take the VSS?
Old Mar 22, 2005 | 09:13 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you will also need to get the speed buffer & it's connector & wiring.
as far as i know, the birds & camaros with electronic clusters used the same VSS so it should would work. you will probably
need the gear off the output shaft of the trans too, but a trip to the dealer should get you the right 1.
Old Mar 23, 2005 | 12:47 AM
89V6FBIRD's Avatar
Thanks, thats what I needed to know....
Now I know that 2.8 V6 cars got 3.42 gears out back, so I'm gonna safely assume these gears will work w/ a 3.45 rear end.
GTAman
Jul 3, 2024 07:29 PM
69GTOby
Apr 18, 2016 02:34 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
