Overhead console wiring
Car: 1987 Chevrolet Camaro SC w/ T-tops
Engine: 2.8L V6
Transmission: Automatic
I bought an overhead console a few months ago and was about to install it when I realized the wiring was way different. The console has 3 wires (white, orange, and black). The wiring going to the old light in the car has 2 wires (both white). Would I still be able to wire this up?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In case you haven't done a search, you might consider it in the future--by the way, welcome to the boards. The first link should give you what you want, the second might provide further info:
https://www.thirdgen.org/newdesign/t...dconsole.shtml
https://www.thirdgen.org/techbb2/sho...hreadid=226910
JamesC
JamesC
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
I think I may have the wiring for my old overhead...... if you are interested.....
Plug and play is always more fun that hack and jack....
Engine: 2.8L V6
JamesC
JamesC
I mounted my console so long ago that I truly don't remember what color the wires to the dome light were. I don't think the color problem is significant, however. Screw the black wire to ground, then trial fit by stripping and twisting the remaining two pairs. You've got a 50% chance of being correct--if not swap and you're there. Running a complete harness under the headliner and down the a-pillar would be a PITA since you'd stand a good chance of breaking something, and of course, you'd need to know where the harness ended. If you choose to do that, check the following link toward the bottom which shows the a-pillar and various fasteners:
https://www.thirdgen.org/techbb2/sho...hreadid=226909
JamesC
JamesC
Engine: 2.8L V6
JamesC
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
