How do you check to see if your battery has a drain?
Old Mar 25, 2005 | 09:38 AM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: built 700r4
I just want to rule out that my batter is getting drained by a bad ground. I know you take a cirtuit tester to it but I'm not sure of exactly what the process is.
Some one fill me in, please.
Old Mar 25, 2005 | 01:00 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Use an current meter in series between the negative battery cable and the negative battery terminal. (Disconect the neg. battery cable) If the draw is more than 200 milliamps (I think) start pulling fuses one at a time until the draw is reduced, and your problem is something on that circuit. Someone else can confirm what the correct current draw is.
Old Mar 25, 2005 | 04:16 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
What about a circuit test with just a light no meter?
Old Mar 25, 2005 | 11:44 PM
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I have never used a test light to test current draw from a battery, but I probably won't be sensitive enough to detect a small draw. If you have a relatively fast draw, it should work.
It's easy enough to try, if it lights up, you know you have a problem. If it doesn't light though, don't assume your okay, it may be too small of a draw.
Old Mar 25, 2005 | 11:59 PM
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I checked the shop manual, it should be 25mA or less, and you need to wait 60 seconds after connecting the meter/light for the computer to power up.
Frozer!!!
Jan 19, 2024 04:55 PM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
