Car will not crank
Car: '87 Firebird
Car will not crank
Hey guys;
Tried to start my car today and it would not crank, no click or anything from the solenoid....checked the battery and connections to starter and all seemed well (had power for everything else). So what i did was use a wire to jump from the crank fuse to live fuse (with key in on position) and it started up.
So....I know its not the starter or wiring to the starter so I am thinking it may have something to do with either the ignition switch or the neutral/park switch. Would anyone know which it may be or how i can check if they are bad? Also where is the neutral safety switch located?
Thanks, Kyle
PS car is 87 firebird 350TPI/Auto
Thanks, Kyle
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
the nuetral safety switch is located on the base of the shifter. have you tried to put the car in nuetral and see if it would start then?
Car: '87 Firebird
yeah, i've tried moving the shifter around and starting it in neutral but with no luck. I hope to get a chance to look at it again today,
