Damn hi beams
Old Mar 30, 2005 | 01:16 PM
violentgod1's Avatar
Car: 1989 RS
Engine: 305 ci v8 LO3
Transmission: WC T5
Damn hi beams
Im having a problem where when i try to turn on my hi beams the turn signal lever doesnt click or even try to. The turn signals will turn on but you gotta try kinda hard. Is there some switch inside the column that should be replaced. It wont pass inspection again unless its fixed.
Old Mar 31, 2005 | 10:47 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the rod going to the dimmer switch which is located above the ignition switch (not the lock cylinder) on the steering column under the dash.
Old Mar 31, 2005 | 01:51 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
I have this same problem. Do you have any pics of the rod that you are talking about?
Edit: I found it but thanks for pointing me in the right direction.
Old Mar 31, 2005 | 03:20 PM
Car: 1989 RS
Transmission: WC T5
I figured out that my turn signal lever wasnted seated right and the switch in the column wasnt mounted properly so i went in and screwed it down and adjusted the lever and it works now. I thought i was going to have to replace the switch inside the column. Thanks
gta892000
Aug 11, 2019 11:16 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
327IROC85
Sep 23, 2015 12:11 AM
