No Turn Signal
Old Apr 3, 2005 | 01:46 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
No Turn Signal
I need help before the cops pull me over for it. my turn signal stop working. one day it was flashing veryfast then it stop working. it will flash when i put the emergense light on but not the signal. it is a 87 formula 350. thanks
Old Apr 3, 2005 | 07:47 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Replace the flashing unit under the dash. Cost a couple of dollars at the parts store, they will know what you need.
Old Apr 4, 2005 | 07:14 PM
Car: 91 formula
i but a new flasher in but nothing happend. the hazerd lights do still flash. put the turn signal do not. Anyone.
Old Apr 6, 2005 | 04:48 PM
Car: 91 formula
i was reading the chilton book and 82-84 it shows the flasher unit. But for 87-89 it will not show it.
Old Apr 6, 2005 | 06:43 PM
PaceCarChris's Avatar
Car: 82 Indy 500 Pace Car
Transmission: TH350
I had a similar problem- left turn signal would not work, hazards operated fine (separate circuit) so it wasn't the bulbs. Replaced the flasher unit but no go. Turned out to be a bad headlight ground. I just cleaned them up and everything worked again.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
